So, I recently finished my first AIO cooled build.
I used the x62 on the i5 8600k and made the fans PULL air through the rad and out the front of my case, admittedly I did it accidently and wanted it to pull air from outside however my idle temps are 30 - 35 [Sometimes spikes to like 45 - 50 for half a second] is it worth changing or are my temps okay?
System Specs
GPU - Asus ROG Strix GTX 1080
CPU - Intel i5 8600k @ 4.8Ghz
Motherboard - Asus ROG Z370-F Gaming
Ram - G.Skill Trident Z RGB 16GB 3000Mhz
Cooler - NZXT Kraken x62
PSU - Corsair RM550x
Storage - Samsung 860 EVO 250GB / 1TB Barracuda
Case - NZXT H500
https://linustechtips.com/topic/976671-aio-fans-question/
So basically the front of the case now is the exhaust?
Where's your intake?
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/976671-aio-fans-question/#findComment-11796529
Well, I am not actually sure, my top fan and rear fan are exhausting but im not too sure on the kraken, what logo should be facing the outside of the case on the fan? The NZXT only logo or the side with the logo and details?
System Specs
Case - NZXT H500
https://linustechtips.com/topic/976671-aio-fans-question/#findComment-11796634
Side note : I have the stickers facing outwards at the moment, if I make the stickers face inside the case, the fan cables are visible and it doesnt look right.
Any idea?
System Specs
Case - NZXT H500
https://linustechtips.com/topic/976671-aio-fans-question/#findComment-11796642
The environment you have created is called Negative Air Pressure - you are sucking air in through every tiny crack in the case.  This isn't necessarily a "bad" thing if your temps aren't being affected - it means your case has a lot of areas you can suck air in through - however the issue this creates is a VERY dirty environment going forward - you will have to clean your PC up a lot, as the dust buildup will be atrocious.
You need to have incoming air through your front of your case and the top and back as exhaust.  Currently your setup is dependent on sucking in air through holes it "shouldn't" - if that air gets blocked (dust buildup is the first culprit) than you will have heat issues and heat is bad ;)  I see no reason to force myself into a high heat situation with components.
EDIT - Get a match or incense, and let the smoke drift around the case and see where it gets sucked in, you will easily be able to tell if something is intaking or exhausting (just using a lighter will tell you that quickly)
EDIT 2 - I prefer super positive pressure environments - and utilize my screens to catch the dust before going in so that cleaning those usually means I only clean my PC internals 1 time a year.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/976671-aio-fans-question/#findComment-11796755
