Hi, i've just got my hands on a i7 8086k with a 240mm aio cpu cooler... currently using an aorus z370 gaming ultra motherboard. 4.9ghz@1.35Volts. 5ghz aint stable for me even when i crank it up to 1.4Volts. as i seen people going all the way up to 5.1/5.2 ghz...
am now planning to get a asus maximus m10f hero motherboard. will this fix my problem?
https://linustechtips.com/topic/976668-does-motherboard-affect-overclocking-limit/
the mobo can affect the oc capabilities.
this can be because of power phases and how they deliver then to your components. generally more are better
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
Hard Maybe. It all depends on silicon lottery here. You could have a chip that just cant stay stable above 4.9 no matter what you do regardless of new power delivery, or it could go well above 5Ghz. No way to know for sure until you test on another board tho unfortunately.
Main Rig: cpu: Intel 6600k OC @ 4.5Ghz; gpu: Gigabyte Gaming OC RTX 2080 (OC'd); mb: Gigabyte GA-Z170X-UD3; ram: 16 GB (2x8GB) 3000 G.Skill Ripjaws V; psu: EVGA 650BQ; storage: 500GB Samsung 850 evo, 2TB WD Black; case: Cooler Master HAF 912; cooling: Cooler Master Hyper 212 Evo, Lots of fans, Air!; display: 4k Samsung 42" TV, Asus MX259H 1080p audio: Schiit Audio Magni Amp w/ Audio Technica M50x
Yes it does.
When i used my Z370-F Gaming, it's okay.
When i used my Maximus X Hero, it's better.
When i used my Z370 Godlike Gaming, it's hotter at idle but overclocks like a champ i can go 5.5ghz on AIO.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
does power supply affect it as well? im using a fully modular 550w power supply. 1070 graphics card
1 hour ago, mikedrewsmy said:
Yes it does.
well, godlike will definately be out of budget, might as well go z299 for tat price ya? maximus x or hero or formula does it has a difference? its about 50usd price difference from my place
Basically same thing unless you're going for Close Looped Liquid Cooling then go for Formula.
wats the difference between hero and formula? n wat does aio liquid cooling has to do with these ?
get  hero then.
Hero boards are middle-ground for ROG, while Formula is a step or two up.
ROG STriX --> Ranger --> Hero --> Formula / Code -->Apex / Extreme
ROG Gene = m-ATX
ROG Impact = ITX / m-ITX
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Are there any load line calibrations you can make?  And have you visited other forums specific to your current board to get some more guidance from folks with experience with your board?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
would depend on the quality of the PSU. how consistently it delivers power. most mostly its not a massive issue
Razer Blade 14
Also an XBOX one s.
