Hello there, currently i have Asus Prime B360M-K motherboard in my mid tower pc case, which i wish to downsize into sff pc case. My friend told me that my mobo isn't mATX, it's FlexATX because of the size (normal mATX will size 24x24cm, meanwhile mine is 22.6x18.5cm)
Is there any sff cases that can fit my mobo? This choice can safe my budget but if there's no choice then i guess i'll switch to itx board.
And also other note, I prefer case have shape like NCase M1, Cougar QBX, Kolink Satellite rather than cubic case. Thanks.
https://linustechtips.com/topic/976516-help-looking-for-a-sff-case/
B360M-K is mATX. No one said mATX boards have to be exactly that size, they could be smaller (but not bigger). As long as the screw holes match ATX standard, it's an mATX board.
Desktop benching:
28 minutes ago, FK2tame said:
any other suggestion on sff case for mATX?
If you can stomach the price tag
http://www.sliger.com/products/cases/cerberus/
