none of them are good, get a corsair CX or coolermaster masterwatt instead.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795082
I would recommend a AX760i its a bit more then their CX line but is a more quality and modular cable management and you can use the iLink software to control the fan speed and look at its temp. But I have no idea what your system specs are.  If you don't need that high wattage and will always use only 1 video card then grab what Herman said. 600 or so watts will be fine.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795101
i have a i3 8350k gtx 960
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795127
You are comparing a $50 PSU to a PSU that is $200 that has been discontinued for quite some time...
Most single GPU and CPU computers will work fine with a 400W PSU. 600W PSUs don't make any sense what-so-ever.
The fact that the guy is looking at low end PSUs, probably says they have a cheaper system (or they are spending the money in the wrong places).
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795137
i dumped most my money into a ssd and cpu and a budget oc able mobo but the last compoent i need is a power supply and i only have 70$! please help! i did a watt checker onlie and it said my system ate 433w and perferd me a 500watt power supply
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795147
Ok then grab the Corsair RM 650x and you will be set.  It's gold certified and modular cable management and 100 dollars shipped.  In the future it can handle a 1080 GTX no problems.  Corsair RM 650x Also its Gold certified.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795148
also is that 39$ evga power suppky fine the 80 plus white or? any other options for that much
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795149
after tax is 140 for me in canada! i only have 70$ left but i wouldnt like to spend more than 50 if necessary beacuse i still need case fans
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795151
Good one snapcrackpop and Comic_Sans_ms.  Im thinking in the future if you want to get a 1080.  If he gets a 500watt or lower you can forget about a video card update pretty much.  Or you can go the EVGA route and get a cheapo PSU for 60 bucks. 500watt.  But don't expect a new video card in the future to work properly on it.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795153
well if i really want to upgrade in the future to somthing that needs alot more power i will probally just upgrade thepsu then as of rn i have no money to put into a psu
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795161
You said your PC has a i3 8350k, and a GTX 960. You will EASILY use under 250W.
https://www.anandtech.com/bench/GPU15/1240
Get a Corsair CX or CX-M (or even better, a Corsair Vengance), BeQuiet PurePower 10, Antec Earthwatts Pro instead.
You will be fine with a 400 or 450W PSU. And you probably shouldn't use a low end PSU with a 1080ti anyway, so when you upgrade (which you likely won't, and will just get a new PC instead), get something like a RM550x.
12 minutes ago, Turtle Rig said:
Good one snapcrackpop and Comic_Sans_ms.  Im thinking in the future if he wants to get a 1080.  If he gets a 500watt or lower you can forget about a video card update pretty much.
No. You are really wrong about that. A PC with a GTX 1080ti and extreme edition uses 380W AC, so about 320W from the PSU. A 400W PSU should suffice for most single GPU and CPU computer.
https://www.anandtech.com/bench/GPU17/1913
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795172
Good post.. I sorta want him to be future proof that's all.  Also I don't know if he wants a modular PSU.  If he doesn't care about modular cable management then for that system a 400watt will suffice.  However its not future proof.  I think his decision is made to just wait it out until he does a full upgrade to get a PSU then.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795184
so after mail in rebate these 3 are pretty cheap which 1 would u guys buy
corsair 550 white
https://www.canadacomputers.com/product_info.php?cPath=33_1238_442&item_id=119717
evga 500 80 bronze
https://www.canadacomputers.com/product_info.php?cPath=33_1238_442&item_id=123142
750w rgb gamdias
https://www.canadacomputers.com/product_info.php?cPath=33_1238_442&item_id=123890
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795216
Evga is a good company, but I trust Corsair more and they have never let me down.  Grab the Corsair 550 white.  The 750w will make you future proof, but if you don't care about the future and care about the now then grab the 550 white like I said.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795222
corsair 550 white
evga 500 80 bronze
750w rgb gamdias
None of those. I cannot find anything about the gamdias, and the other 2 are a no.
Get this, a Corsair CX450M. Much better.
https://www.canadacomputers.com/product_info.php?cPath=33_1238_442&item_id=096571
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795228
please don't give advice if you don't know what you're talking about.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795236
what did he say wrong what do oyu think i should get?
thinking that you need a 750w PSU for a GPU upgrade and that it's "futureproof", recommending entire brands instead of exact units(every brand sells crap), one of his replies makes it sound like he thinks there's no modular 400-450w PSU out there. the CX450/M and coolermaster masterwatt are good budget PSUs at around $60 or so.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795263
With the $20 rebate, that's a pretty damn good price.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11795266
12 hours ago, snapcrackpop said:
is the 80 plus bronze worth the extra 15$ or is the 80 plus white fine?
No, both are shit and utter crap and must be avioded!
Get a Bitfenix Formula, Whisper M, be quiet Straight Power 11, if possible.
400-550W is enough.
IIRC, Bitfenix Formula is available for that Price on Newegg.ca
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11796486
Sorry Herman, I just meant if he wants a 2080 GTX in the future he might run into trouble with a 400 or 450 watt.
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11797754
Your right man my bad.  I was just thinking if he wants a 2080 or a 3080 in the future or SLI possibly.  But looks like he doesnt want to ever SLI ,, so ya your right 750 is over kill. my bad...
https://linustechtips.com/topic/976500-which-power-supply/#findComment-11797770
