Hello!
So I need an AIO for the NCASE M1 and I've tried searching for 240mm fans but I don't know which to get.
RGB is not a must because the lighting won't be seen much in the case so that is no worry.
Thermals is important in SFF builds so I am prioritizing that over the acoustics.
Ones I've heard that's good are the Corsair H100i Pro and H100i V2 but if it were to be between those two, but which performs better?
Do help me choose an AIO that will do a terrific job for a good price maybe less than USD$180 (the lower the better).
Also, if air cooling is a better option to go with then which should I go for? (previously looking at the Noctua NH-D9L).
Here's my build for now if this concerns anything (feel free to comment about it if any changes should be made): https://pcpartpicker.com/list/qf6kbX
Little intro: SFF mini-ITX Productivity (Motion Graphics) PC Build Budget USD$2000-2200 (the lower the better)
Thank You for reading!!
Mentioned components for easy searching :)
NCASE M1: https://www.sfflab.com/products/ncase_m1
H100i Pro: https://pcpartpicker.com/product/hmBTwP/corsair-h100i-pro-750-cfm-liquid-cpu-cooler-cw-9060033-ww
H100i V2: https://pcpartpicker.com/product/CrDzK8/corsair-cpu-cooler-cw9060025ww
Noctua: NH-D9L: https://pcpartpicker.com/product/8pgPxr/noctua-cpu-cooler-nhd9l
https://linustechtips.com/topic/976444-aio-for-ncase-m1-help/
5 minutes ago, Densetsu said:
You'll be fine with an air cooler. I use the U9S, but the D9L results are similar. From what I've seen, tubes can be a bit tricky to maneuver, but plenty have done it.
Even with overclocking, thermals won't be bad? Roughly what are their temperature differences between both types of cooling? I'm afraid things will get too heaty, affecting my projects.
https://linustechtips.com/topic/976444-aio-for-ncase-m1-help/#findComment-11794606
H100i v2 worked fine for me.
H100i pro just uses a different generation pump that is not necessarily better (read Gamers Nexus on this for more details) However the tubes might be easier to work with since they are slightly more free-rotating.
https://linustechtips.com/topic/976444-aio-for-ncase-m1-help/#findComment-11794636
Thank you for your help!!
https://linustechtips.com/topic/976444-aio-for-ncase-m1-help/#findComment-11794684
