No, not that big of a difference. More like 70C to 60C, if the fan speeds stay the same (laptops usually slow down fans at the same time, giving even less temperature difference)
Desktop benching:
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11794172
It could help you a little bit when you reach temperatures near throtteling. But besides of that, I wouldn't apply liquid metal. Risks are definitely there.
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11794194
1 minute ago, DESTROYER 123503 said:
But i want the fans to be more quieter because the fans run at 7000rpm and its 70c on cpu and 55 to 65c on gpu
If it's worth the possibility of completely toasting your hardware then go for it, but I'd use something like Thermal Grizzly Kryonaut instead, it's a heck of a lot safer.
According to this: https://www.techpowerup.com/forums/threads/kryonaut-12-w-mk-vs-conductonaut-liquid-metal-73-w-mk.229167/
You get about a 3C decrease in temps, for a much higher chance of ruining your machine.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11794250
It's okay to use liquid metal but it's a good idea to use transparent nail polish to put on the parts around the die.
So you can't short those components out.
But still I'm not sure if I would do it on a laptop xD
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11794286
I did it on my GE62 6QF, can't remember the details but it didn't give any more performance (at stock settings) but it did lower temperatures. I can't confirm if it was related or not, but the laptop suddenly stopped working some time after applying the LM.
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11794329
Speaking from experience here ( i delided my old i7 3770k) , but liquid metal isn't worth the risk . Don't get me wrong : i do think deliding your processor is definitely worth it , but not liquid metal.
I started out my delidded 3770k with plain old thermal paste ( NTH1), but eventually use LM a bit later on. The temperature gains are marginal , and honestly not worth the risk of shorts, corrosion ( if applicable ) and just the simple fact that you'll need to re-apply the LM fairly often .
You're probably just as well off buying quality thermal paste and using that instead between the die and IHS.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11794364
If you are capable and you have the right delid tools for CPU side of things and can follow instructions then the risk are virtually none IMO, expect user error. When dealing with graphics cards same story follow a tear down video/web guide if any and have at it, be prepared with a full set of micro heads with various tips, the tear down guide is not really needed but recommended points on the GPU can be delicate, don't want to try to force something off. Never use on aluminum like it says right on the box.
I still need to do my GPU at some point but the delid on my i7700k with a mono block on an Apex motherboard was amazing, reached a final OC of 5.3GHz with negative -2 AVX, had too have that on to make stable in things like prime 95, temps do not go above 60c/@23c ambient basically no matter how long you run the dam test close to two gallons of distilled water between the two loops, at idle 1-3 degree spikes above ambient . Without the delid and liquid metal with NO GLUE on IHS and also liquid metal on IHS and heat sink, that would never be possible. Looks like Intel is going back to solder on the high end gaming main stream chips i9 9900k, so might not have too anymore for CPU's.
Thermatake Tower 900 Build
Intel® Core™ i7-7700K @5.3GHz -2AVX / ROG MAXIMUS IX APEX + EK-FB ASUS M9A Monoblock
ROG-POSEIDON-GTX1080TI 11Gb @2114MHz/5780Mhz / DIMM.2 970 EVO 2TB NVMe PCIe M.2 x2 RAID 0
EVGA SuperNOVA 1600 P2 80+ PLATINUM / Hisense 65" H9 Plus 4k HDR
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11795935
Double post
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11795995
16 hours ago, DESTROYER 123503 said:
I mean linus lm his $3000 laptop it didnt go wrong.
Thats whats called being stupid for a video, gets more views, it also comes with these little needle tips which is what I used it allows it to slowly come out and ball at the end. Common sense should direct a person to "Test" an application on a test surface just to see how sensitive the product is coming out. Atleast with me it did because the hardware it was being used on was purchased by me lol and I did not want any fuck ups, and also knowing its very difficult to clean.
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11798807
you will get more quiet fans with light works loads, but high ones, the fans will most likely spin up to max or near max,
but the temps will be much better, at lighter loads the temperature difference isnt really the much different unless you edit the fan curve
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/976401-liquid-metal-cooling/#findComment-11798835
