how loud is the beep? Is there anything else misbehaving?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976369-noise/#findComment-11793911
Try touching what you think is making the beep with a small piece of wood
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794152
32 minutes ago, bigmouthbob1 said:
How will that help?
well you can find out if some component is vibrating when it shouldn't be, and since wood is non conductive, you won't break anything
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794644
1 minute ago, bigmouthbob1 said:
It’s not vibration it’s more of a squealing
All sound is caused by some sort of movement. A small object shaking back and forth very fast causes a high pitched sound.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794661
It does sound like a small speaker. Is there one attached to your motherboard?
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794663
Just now, bigmouthbob1 said:
I don’t think so.  Unless this is one
That's your sound chip, it doesn't produce sound it just processes sound data for your speakers. A motherboard speaker would be a little cylinder with a hole in the top.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794678
Nope in fact it came unattached
well the important thing now is to identify where exactly the whine is coming from. Have you turned on the computer without a graphics card, or have you unplugged fans while they were spinning? I would assume something mechanical would make a noise like that.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794700
Is it possible to listen to where the sound is coming from inside the PC? It may be easier to remove the motherboard and run it outside the case. You can just leave it on a cardboard box.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794714
Alright I took it out and I took out the graphics card and it turns that was it so what do I do
https://linustechtips.com/topic/976369-noise/#findComment-11794760
You can try to find what part of the graphics card makes the noise.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976369-noise/#findComment-11794898
