the Cryorig H7 seems ever so slightly out of your budget, so I'd say the cheap old 212 evo works pretty nice.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791520
Hyper 212 Evo is a solid option. Always recommended.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791522
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791552
2 minutes ago, aisle9 said:
oh that m9i does look beefy, and a lot more stylish
Primary PC:
PSU tier list
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791559
It's only a 92mm cooler, but it's more or less on par with the older 212 stuff.
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791611
53 minutes ago, aisle9 said:
Ok going fornthat cooler thxs
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791660
1 hour ago, meme smurf said:
my dude if your planning to overclock with40$ your not going to go that far... i got 4.8ghz at 70c max with my 240mm watercooler i got for like 60-70 bucks. in your case i dont see you getting much past 4.5ghz
(btw) decent choice in cpu i also have one its served me quite well i must say
Probally just going to clock to 4.5ghz thrn later down the line if i need the boost i will get a better cooler and go for 5 ghz or probally just upgrade my pc
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791663
1 hour ago, snapcrackpop said:
No. It's just an older version of the 212 with a second fan and a higher price tag.
Also, it looks like a period.
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11791812
On 9/26/2018 at 5:39 AM, snapcrackpop said:
M9i is at same level with that....
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11797146
What case and ram are you using?
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11797757
https://linustechtips.com/topic/976130-cooling-for-cpu/#findComment-11798357
