I have a 16GB Corsair LPX kit that is rated at 3000MHz, but whenever I try to set it to that with XMP, it will work and then soft-lock my system while simultaneously resetting the BIOS to default.
How can I get it to run at 3k and not crash? Since I'm on Ryzen it would be pretty nice to have my RAM running at full speed instead of nearly 2/3 speed.
The specs of my PC are as follows to stave off the inevitable question.
Ryzen R7-1700x
Hyper-212 evo
Gigabyte Aorus x370 k7 ver 1.0
Corsair LPX 16GB 3000
Aorus RX 580 extreme
EVGA Supernova 750
Thanks.
https://linustechtips.com/topic/976062-ryzen-pc-ram-clock-problem/
Ryzen IMC isn't very strong so it might be unstable above rated speed. If I'm not mistaken first gen ryzen is limited/rated at 2400mhz so anything above that isn't guaranteed to work. try slightly lower speed or loosen timings.
Ryzen R7-1700x
Hyper-212 evo
EVGA Supernova 750
Thanks.
I remember having issues with 3200MHz LPX memory when I got my Ryzen system. The farthest i could get it to go was 2966 or 2933 or something like that. it seemed to me that Ryzen IMC didn't have a multiplier for 3000MHz
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Try 2933 if the above suggestions dont work. This multiplier seems far more stable than 3000 back when Ryzen just came out.
Desktop benching:
@DayenI would suggest you change your SOC voltage to 1.1V and if that alone doesn't work then up the DRAM voltage a little.  Feel safe going as high as 1.45V, but I don't suspect you will need to go anywhere near that high for that speed.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
