4 minutes ago, Nastylucas said:
Hi all, I wanted to get your feed back on this question. As PC a Builder/Gamer, what are the most common features you look for when purchasing a PC case?
I personally chose the Define R4 for the noise reduction foam, Easy Cable management and the front door to cover the ugly optical drive.
Typical things people look for is probably, Window/Tempered Glass, Lighting, Cable management, Specific look, feel or material, Radiator compatibility and Power Supply Shroud.
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789101
  • Adequate Airflow for the system I'm building. If it's an i3-8100 web surfing system, it doesn't need a mesh front panel with 3x120mm fans.
  • Build quality. Do they use thin steel and plastic? or is there some rigidity ot the frame? How are the HDD bays and SSD trays constructed, if any?
  • Ease of cable management. Do I have what I need to easily keep everything manageable, or do I have a case that I need to push the side panel closed? Does the case have a PSU basement?
  • Dust Filters. Are they easy to remove? Are they too restrictive? How many sides do they cover?
  • Side window. In most cases people like to see the interior of their system, so a Side panel is nice to have, especially tempered glass. On that note, a decent Tempered glass mount. Some are garbage like the Corsair 275R, some are great like the Evolv Series with their hinged design.
  • Hardware compatibility. Can i fit a large Air tower, or my AIO/watercooling loop? How long of a GPU can I use? Do I need more than 2 HDD's?
  • I/O. Does it have a modern configuration? do all the plugs match my motherboard, or planned expansion?
  • (Optional) Colors. Do they only offer it in black? Or are their white versions? What about other colors?
Things I do not look for:
  • RGB lighting. These are purchasable outside the case (case fans, RGB strips, etc) and I'd rather buy a good case without RGB and add it later than a bad case with RGB.
  • Vertical GPU mount. This blasphemous trend puts GPU's way too close to side panel and chokes fans, resulting in a loss of performance in games. Rule of thumb: Aesthetics are good as long as it does not significantly impact performance!
  • 5.25" Bays. There's less and less need for these now-a-days. For some people this is still really important.
  • (optional) Silence Optimized cases. Since I wear headphones I'm okay with a little bit more noise within reason, but some people might not be.
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789142
Pretty much got all the bases here, the only thing I can add is longevity. Is this something you can see yourself still using in 3-5 years time without hating it.
Does it have enough expansion space in it for whatever projects you might want to tackle, ie customer water cooling
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789187
Thank you your in-depth response. There's a lot to consider here and it's extremely useful. What kind of I/O would you consider to be useful or needed in a next-gen case? USB 2.0/3.0/3.1, SD Card etc...
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789260
Personally I try to stick with all USB 3.0. Fast charge ports and/or Gen 2 is a bonus (usually in Type C) but of course this assumes I'm build with a motherboard that has the 19pin Gen 2 header. Reset buttons are very useful. I personally dont care about SD card readers, fan controllers or lighting controllers as those can be done using other methods.
Some people like the I/O on the front, some on the top, some on the side. To me it's not important, but some cases can change the locations (Thermaltake Level 20 VT and Cooler Master Q300L come to mind)
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789276
In regards to longevity, obviously ensuring that that build quality is good, what type of aesthetic would make you not get bored of it? Case skins maybe?
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789331
Never used a skin personally. But it has to be a case you're in love with. Heck, I find usually cases with a simple but sleek design go a long way because it's just that. Simple and sleek.
Now if you get one of those "ultra cool gamer dude" cases then it may become old and stale after a while. These of course, are all just personal preference.
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789346
*cough* my old Level 10 GT *cough*
To be fair I still like the case but I didnt utilize it enough to justify its size and age (2008!).
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789380
I'm sad that 2008's electronics now look like relics. We're growing up too fast :(
Or technology needs to slow the eff down :D
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789396
Honestly, I still do like that case as well. For the time it was huge! And DVA, yes, tech needs to slow down! haha.
https://linustechtips.com/topic/975901-pc-case-features/#findComment-11789526
