Phantom power or nah?
Go to solution Solved by Sir Asvald,
1 minute ago, Triventular said:
so i should buy phantom power for it?
You need phantom power. I've got a similar mic.
I have a generic condenser mic (bm-800) attached to a cheap external sound card and i noticed that, for me, the audio recorded was too weak for me. Would adding a phantom power supply to my audio setup increase the volume of the audio recorded? thanks. do so to tell me everything i said wrong cuz i'm not good with audio devices on pc.
https://linustechtips.com/topic/975873-phantom-power-or-nah/
it says that it needs phantom power and yes it would increase the volume. The behringer um2 would be a extremely cheap way to get phantom power and at the same time a external ADC
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/975873-phantom-power-or-nah/#findComment-11788787
okay i'll take this into consideration thanks
https://linustechtips.com/topic/975873-phantom-power-or-nah/#findComment-11788802
I had a bm-800 xlr to 3.5. It used to sound weird specially after i compared it with it running on phantom power. The quality increase was very much prominent. Same is the case with USB based microphones, if they support xlr then you should use it. That always end up increasing the sound quality. (to the best of my knowledge)
https://linustechtips.com/topic/975873-phantom-power-or-nah/#findComment-11788840
19 minutes ago, Triventular said:
it says on the box its a condenser mic but my problem is its too weak cuz its only using xlr to 3.5
XLR or not, condenser microphones need Phantom Power to function properly, they're designed that way.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/975873-phantom-power-or-nah/#findComment-11788843
https://linustechtips.com/topic/975873-phantom-power-or-nah/#findComment-11788853
