Hello, this is my first post on LTT so I'm sorry if I do anything wrong but please bare with me. My friend recently bought an Asus MG248QE monitor and we've had a hard time finding calibration/settings for it online and just wanted to know if any of you guys know how to calibrate it and mind sharing it?
Thank you in advance! :)
https://linustechtips.com/topic/975867-mg248qe-calibration-help/
Have you checked this out: http://www.tftcentral.co.uk/articles/icc_profiles.htm
And this review where they talk about the best settings?
Scratch that, the above is for the MG248Q, not the MG248QE
Edited by Dissitesuxba11s
You could spend a little money and buy a proper calibration tool between yourself and your friend. They are not THAT expensive, and can be used for all displays.
The problem with using a stated set of settings is that each monitor or TV, even those that are meant to be the same, will be slightly different. And using online tools to eyeball it wont always produce the best results.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
