I made a partition and installed linux on the wrong drive
Solved by KarathKasun,
After booting from the Ubuntu media, do the following to remove the UEFI partition...
Use "Try Ubuntu" instead of "Install Ubuntu".
After it loads, click "Activities" in the top left corner.
Type "gparted" into the search box and click the "gparted" icon that appears
Delete offending partition by highlighting it and clicking on the red "no" circle.
Save the changes by clicking the green checkmark.
Click "apply" when asked if you are sure.
Reboot.
