Hi guys,
I changed my 9600 GT for a new MSI GTX 1050 2G AERO. At first, everything worked fine, but then problems started.
In device manager I get the Code 43 on my GPU. I tried reinstalling the Driver because it was already the newest and it didn't solve the problem. I even tried a CMOS reset which I read in one topic somewhere.
I managed to make the GPU somehow work again, but I am back to the Code 43. The weirdest thing is that the GPU has output and works, but not as it should. Only basic functionality.
For example, Windows Aero doesn't work and 3DMark reports that my GPU doesn't support DirectX 11 but it didn't report this when the GPU worked.
My OS is Windows 7 x64 and Motherboard is GA-N650SLI-DS4L.
Thanks for any help.
https://linustechtips.com/topic/975258-gpu-code-43-driver-reinstall-didnt-help/
Where are you downloading drivers from
Primary PC:
PSU tier list
How many watts do I need?
Try downloading GeForce experience, see if using it helps
Primary PC:
PSU tier list
im guessing dead card, 43 is a hardware problem IIRC
Builds:
