Hello, I installed a RX 570 today, however every time I attempt to install my drivers they just don't work.
I've restarted 4 times now, reinstalled the drivers each time, and they still don't work. I think I am using the most recent adrenaline drivers. I am currently trying to download the Gigabyte drivers for this, but its going to take about a hour or so due to my slow internet.
What should I do while waiting?
Who needs fancy graphics and high resolutions when you can get a 60 FPS frame rate on iGPUs?
https://linustechtips.com/topic/975208-radeon-drivers-will-not-install/
Could you specify the "they just don't work"?
What GPU where you using before? Did you uninstall the previous driver?
If you find any grammar or spelling errors please fill out entry permit A38, thanks.
Greetings from germany
Profilepicture by Chibiterasu-chan
Hello there, I’ve been at it attempting to install my drivers for my Gigabyte RX 570 for 7 hours now, and I am at the point where I may give up for the night. I have no idea what is wrong other than it just refuses to install the drivers.
I have cleaned out old Nvidia drivers for my 660 using the DDU utility, and have done it for my AMD drivers twice now too.
I have reflashed the BIOS and it still won’t update.
I have gotten the disk drivers, the most new drivers, and the drivers from Gigabyte’s website. None of them work.
I’ve attempted to start in safe mode to install them.
I’ve probably done a few more things that I’m forgetting due to how stressed out I am by this at the moment.
I tried to contact AMD support but they’re closed on Sundays. What should I do? I literally just wanted to play DOOM for an hour or two, but have been doing this instead. Any help is insanely appreciated, I am on the verge of just giving up for the night.
Give us more detail. Are you getting errors? Is it crashing? What OS are you on? We need more information.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
I see you have the MSI H61-E paired with the i5 2400. Is the on-die GPU off? Are you connecting your monitor straight from the RX 570?
FragBox: i7-2700k 4.7-12GB Samsung 1600mhz CL8-ASUS P8Z68-V/GEN 3-R9 Fury Nitro custom bios-NZXT HALE90 750W-NZXT s340
AOC i2267WH IPS
Yes and yes.
I only got two errors with codes: Code 43 in device manager, and in Windows Update I got 0X8024CE2B. It’s not crashing, however when I get to the end of the installation, I click either “close” or “restart” and nothing happens. Both just close the program and don’t restart my PC. I’m currently on Windows 10 home.
I’ve been working on it for a while still, I’m no farther than where I started from. AMD can’t be contacted until tomorrow, but I really want to get this PC running tonight. Anything I can really do anymore?
