My Front Intake Fan is dying
Arcana
Hello, my Intake Front Fan is Dying its slow spinning already. should i care about it or ill just leave it like that? by the way my case is NZXT Phantom Full Tower, front 1x / side 2x / top 2x and 1 rear fan
53 minutes ago, kb5zue said:
If you know the fan is failing, then why not go ahead and replace it?
oh its not the fan. i tried other switch and the fan still work on his rpm, theres something wrong my my case connection?
On 9/23/2018 at 9:05 PM, YourNewPalAlex said:
a minute of silence for your fan.
try to plug it in, in another fan header on your mobo
too far away on my front fan
you can always borrow an extension cable, first you pay for the cable, you try it out. See if your fan is dead and then refund the cable again. Or you can just do a "every man's pc" and just disconnect the fan, temporarily connect it to different fan header, and hold it until you figure out if its ok or not.
