PCPartPicker part list: http://ca.pcpartpicker.com/p/2vbOc
Price breakdown by merchant: http://ca.pcpartpicker.com/p/2vbOc/by_merchant/
Benchmarks: http://ca.pcpartpicker.com/p/2vbOc/benchmarks/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($249.79 @ DirectCanada)
Motherboard: ASRock Z87 Pro3 ATX LGA1150 Motherboard ($100.00 @ Vuugo)
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1600 Memory ($60.00 @ Newegg Canada)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk ($89.99 @ Memory Express)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($64.79 @ DirectCanada)
Video Card: Asus GeForce GTX 760 2GB Video Card ($266.00 @ Vuugo)
Case: NZXT NZXT H230 Black ATX Mid Tower ATX Mid Tower Case ($83.63 @ Newegg Canada)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($49.99 @ Memory Express)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.00 @ Vuugo)
Total: $982.19
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-04 02:24 EST-0500)
Thanks!
https://linustechtips.com/topic/97468-first-build-advicehelp/
I'd get an 8320 and with the money saved, get a GTX770.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1303738
+1 for this. Never get a 4670K if you can get a better GPU by going AMD.
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1303758
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($148.00 @ Vuugo)
Motherboard:  Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($108.12 @ Newegg Canada)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ DirectCanada)
Video Card:  Gigabyte GeForce GTX 770 2GB Video Card  ($368.98 @ Newegg Canada)
Case:  NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($64.98 @ Newegg Canada)
Power Supply:  Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($64.99 @ Amazon Canada)
Total: $983.05
(Generated by PCPartPicker 2014-01-04 02:35 EST-0500)
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1303763
Motherboard:  Asus M5A97 LE R2.0 ATX AM3+ Motherboard  ($86.84 @ DirectCanada)
Memory:  A-Data XPG Gaming Series 8GB (2 x 4GB) DDR3-1600 Memory  ($77.99 @ Newegg Canada)
Storage:  Sandisk  128GB 2.5" Solid State Disk  ($82.50 @ Vuugo)
Storage:  Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($119.75 @ Vuugo)
Video Card:  Asus GeForce GTX 770 2GB Video Card  ($349.99 @ Memory Express)
Case:  Fractal Design Core 3000 USB 3.0 (Black) ATX Mid Tower Case  ($79.99 @ Memory Express)
Power Supply:  EVGA SuperNOVA NEX750B BRONZE 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.98 @ Newegg Canada)
Total: $1035.04
(Generated by PCPartPicker 2014-01-04 02:47 EST-0500)
Slightly more expensive but you get more HDD space.
Quote me to get a reply!
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1303805
u should put one more DIMMs i.e (2 x 8gb) for dual channel memory...or if u want to run only 8 gb u should have installed (2 x 4gb) DIMMs..it offers dual channel memory architecture which will increase ur memory performance..
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1303833
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1303838
Total: $982.19
Thanks!
It's a good build that will perform well.
Do you really need the CD/DVD drive?
I noticed that there is no after-market cpu cooler. Do you intend to get one later or are you going to stay with the stock cooler?
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1304178
The difference is negligible
It is negligible if u cant see it...it sure increases the gaming performance and also reduces the bottlenecks of your system...2 DIMMs are gonna work in coordination increasing your read/write rate and bandwidth... and it the performance levels are diffrnt for diffrnt clock speeds...like for instance u have 1600mhz....so in dual channel the performance improvement will be more than that given by a dual channel in 1066 or 1333mhz...
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1304662
I was intending with staying with the stock cooler, and upgrading later if I over clock.
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1305411
I've done my research on dual channel, and buying a second DIM, for two 4gig cards is slightly too expensive to justify it, and having a single 8gig card makes it easier for expansion later.
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1305425
Ya it makes easier for upgrading later...if u plan to do that then its good...
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1311087
What's the system being used for?
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1311133
Gaming. Planet side 2 (validus gamers, represent!), fallout, etc.
Alright.
Edits: http://ca.pcpartpicker.com/p/2wjag
https://linustechtips.com/topic/97468-first-build-advicehelp/#findComment-1315889
