Just Wondering if Temps are OK for long Term XFX RX 580
KaosuMaster
My build
DIYPC Skyline-06-WR Black/Red Dual USB 3.0 ATX Full Tower Gaming Computer Case with 5 x 120mm Red Fans, Hot Swap Docking
  I was monitoring Temps on my new PC I saw the graphics card under load was hitting 75C -79C
  I looked up and its max temp is 90c.  So I looked into how to lower the temp. I  found  the only way  was to use its  program to change the fan speed and give it more power.
  When i use the program to fix the temp the Monitor and  TV lose signal.  I try to reset the PC and it wont work, it just stays on I have to go  flip the power switch just to turn it off.
  when I reboot,  the Graphics card program rests to default.
TLDR: IS 75C - 80C over long term gaming going  to hurt my video card
5ba2dbb58d044_BaseIdel.thumb.png.2f3f31d366263864f66e0d0192aab207.png5ba2dbe718f6e_Wilegaming.thumb.png.4deccb4fa35e9d8b8e48aac0995a64ca.png
Absolutely not
1 hour ago, Dan Castellaneta said:
Many 580s tend to reach the mid-70s under full load. If you're really worried make the maximum fan speed more aggressive.
 I  put min speed at 2000 and  target at 3300 for fans but  it crashes
  • 1 year later...
Hey, did u manage to fix it in any possible way ?
