Is it possible to check if the GPU is running without CPU and RAM on the Motherboard. Im probably gonna buy a gtx 1080 on offerup for really good price box open brand new, seller has 500+ items sold and 5 star rating from 150 customers. Dont have all parts yet for pc and dont want to get ripped off. Help would be awesome. Thanks.
https://linustechtips.com/topic/973542-gpu-test-without-ram-and-cpu-possible/
If you have a friend with a computer then you can try that... I'm not sure how offerup works. If you're picking the GPU up in person you can ask him to test it for you. If it's being shipped, make sure you get some kind of return policy or purchase protection. I know paypal has good purchase protection.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Pretty much. Here's a quick run-down;
1. Shut down the PC in question, switch the power supply off using the switch on the back of the case
2. Then hit the front power button once, to clear any residual charge. Pc may try to start, that's normal. after that it shouldn't do anything when you press the power button.
3. Open up the case, unbolt the GPU, it's ower cables etc.
4. Fit your new GPU(may need more power cables, depending on the previous card), swich the system on. Listen for any strange noises.
5. Hit the windows button and type Device Manager, then look under 'display adapters' to see if the GPU has been recognised.
6a. Update the drivers if the other card was also an nVidia
6b. Remove drivers and install new ones, if it was an AMD card in there before
7. Boom, you should be done!
For a proper GPU test, you'll want to run a stress tester like FurMark, for a minimum of 30 minutes, as well as a few regular games, etc. This will make sure the card doesn't act strangely when under full load. But don't do both at once!
