CPU Stress Questions
Go to solution Solved by Sakkura,
1. No. It can increase the CPU load, depending on the situation.
2. Yes.
3. Well... yes, I suppose. But it's not common to have the ability to swap.
1.- On gaming, does having a better GPU decrease the CPU stress / load? (so lower temps)
2.- On video rendering, does enabling GPU acceleration decrease the CPU stress / load?
3.- Is the CPU stressed less when doing GPU rendering (3D apps) aside from CPU rendering?
Thank you
https://linustechtips.com/topic/973449-cpu-stress-questions/
