Should I overlock GTX 1060/ Fan Curve or Fan Speed?
Solved by Jurrunio,
1. Set a custom fan curve.
2. No, dont touch the voltage. Not because it's dangerous, but it has literally 0 effect on overclocking. By pulling the slider, all it does is send more volts when clock speed is low. The upper limit of voltage is what you're already using now and you cant increase it by pulling the voltage slider.
As for whether you should touch the power limit, it depends on whether your card runs cool enough (below 75C is where I draw the line) under acceptable fan noise.
3. Voltage frequency curve lets you use the least amount of voltage for that frequency, hence saving power and reducing heat output and noise. You're still limited by the voltage upper limit and power limit.
