Need help!
Go to solution Solved by helping,
One last question. Will I see a worthy increase in performance if I run two in crossfire? I've heard it can go both ways when running dual gpus since the increase in temps is a negative factor
Yes. Your temperatures now aren't high enough for the increase in heat to be an issue.
Why watercool?
https://linustechtips.com/topic/97328-need-help/#findComment-1302197
Full cover block or gtfo.
Just keep it on air.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/97328-need-help/#findComment-1302207
If you have vsync on, yes, if off, the top cards temperature will increase.
AMD diehard & Nvidia Enthusiest
https://linustechtips.com/topic/97328-need-help/#findComment-1302254
Error: 410
https://linustechtips.com/topic/97328-need-help/#findComment-1302296
My case is silence optimized restricting my airflow and since I overclock and game I don't want my card getting to hot. I hit 70 C running bf4 on high settings already.
70° is perfectly fine for a GPU to run. Remember, 290x runs 95° no problem.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/97328-need-help/#findComment-1304307
