Extremely low FPS on AC4
Go to solution Solved by Ineko,
In a city its pretty much at 50FPS now, sometimes 60 FPS if nothing is really happening, just got in to a group fight thing with some guards and it went down to 40's, sometimes 35. This is still with all lowest settings, they aren't great framerates but they are at least better and also my GPU usage pretty much never goes above 48%, do you think that's my CPU bottlenecking it or is the card just being awkward and not going to its full potential? I would also like to point out that my mobo only has a PCI-E 2.0 x16 slot, no PCI-E 3.0, do you think that could also be affecting it? Thanks for all your help anyway :P
The performance increase going from PCI-E 2.0 to 3.0 is pretty much non-existent for current GPUs. Your GPU pretty much should be pinned at 100% most of the time. It definitely sounds like your CPU is limiting your performance.
EDIT: After doing a little bit of research I found that your CPU is basically equal to a i3-2120 performance wise. Which would easily bottleneck a 770.
So, my diagnosis, CPU bottleneck.
I just installed AC4 on my PC and it is running at a ridiculously low FPS on the lowest possible settings, I have a GTX 770, so it's not exactly a weak card but I'm almost never going above 40 FPS when in a city and even worse when in the jungle areas, is anyone else experiencing this? Is the game just horribly optimised for PC? I just feel that this is stupid, why would NVIDIA bundle a game with their card which it clearly can't run well, unless the answer to that is because it is just not optimised correctly and I don't know what GeForce Experience is doing because with the settings it's suggesting I'll almost never go above 25FPS. Is there any way to increase the FPS without lowering the resolution (I'm not even at 1080p), or are we stuck until Ubisoft starts taking PC seriously? I'm so glad I never bought this game.
Mirror's Edge 2. One day.
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/
Do you have the latest drivers?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302078
Do you have Physx on?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302094
how warm does your card get? and what CPU do you use?
My card keeps itself amazingly cool, idle is about 25C and under load it barely goes over 40C, sometimes not even 35C. My temp limit is set to 80C, but like Linus said, GPU Boost hardly works
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302126
looks like your card doesn't ramp up the core clock. check with MSI Afterburner or EVGA precison, check and see if, and by how much your core clock increases.
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302135
AC4 works fine on my  GTX 770. I an max it out and still get above 40 FPS most of the time. Turn off Physx and God rays. Try installing the Beta drivers.
I have the latest available stable drivers, but I'll try downloading the beta ones and get back to you
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302145
Will do after I install the beta drivers to see if that helps, the screen has been black for a good 3 minutes during this driver install, I hope this isn't another problem
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302226
nope, it's fine.
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302230
I'd love to know why AC4 runs so bad on my 780. I think it's just really badly optimized.  <_<
What settings are you running at and what is your rough FPS? And it must be, because even a 770 should definitely be able to handle it no bother at high.
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302270
20 minutes. It's been black for 20 minutes, should I just turn it off and restart it or?
ok, that's not so normal. try restarting your pc, deinstall drivers, and reinstall them
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302310
That doesn't sound normal, i've never had a screen go black that long during a driver install
Happens to me every time I update the drivers on my 680. It's just NVIDIA being shit. I always have to use a keyboard shortcut to restart it.
Although, I heard uninstalling and re-installing the drivers in safe mode fixes this problem.
Sounds more like it keeps itself amazingly under-clocked. Those are the kind of temps you'd expect from a full water cooling loop.
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302767
It's optimized like shit, but that's still ver low FPS, I get around 45 on almost max witrh my 660 Ti.
Just a few weeks ago and I was barely able to push more than 40 on my 780
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/97318-extremely-low-fps-on-ac4/#findComment-1302896
