I'm building a new system and wanted to use a case that breaks the norm. Almost all cases follow the same rectangular design. I want something that stands out, i know of  the Deepcool Quadstellar and Cougar Conquer but was wondering what other cases exist that are unique. My system is a standard ATX form factor so the HP Omen X case wouldn't work despite it being unique. My budget is $500 because i know these cases usually are a premium but i am not willing to spend the $1200 it costs to get an INWIN D-Frame. Any that are found is helpful.
https://linustechtips.com/topic/973095-unique-case/
https://linustechtips.com/topic/973095-unique-case/#findComment-11764098
best advice I can give you is go on modding forums
https://linustechtips.com/topic/973095-unique-case/#findComment-11764116
2 hours ago, Crunchy Dragon said:
Always liked the Genome but i'm considering doing a custom loop and integrating the built in reservoir is near impossible, still and option though.
https://linustechtips.com/topic/973095-unique-case/#findComment-11764395
