CPU is Hotter Than Before
_Hustler_One_
Guys, I have a problem on my CPU temps.
I use i7 8700K with NH-U12S paired with NF-F12 iPPC 3000 fan and bound them with TG Kryonaut.
Long before it was a great performer of air cooling setup. It was 36oC idle and 54oC gaming. The CPU usage is only 20%.
In the last 2 days my temps is raising to 39oC idle and 63oC gaming, same game I play with same setting. I tried to reapply the thermal paste, clean all the cooling properties inside my PC all the vents, the fans, heatsink, pretty much clean the whole PC, but no improvement or at least back to previous temps range..
I think it's not a temperature sensor failure, because the exhaust blows hotter air than before.
What could be possibly wrong???
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
42 minutes ago, seoz said:
What if it's just ambient room temperature that's causing this temperature rise? Was it any hotter/colder in the past two days?
Confirmed not because of the ambient temps. Sorry not to mention that this hotter temps I get is while I'm playing at night, and the previous temps were either day or night only 1-2C difference, but this gives me 9C difference under load. But when I stress tested it with Realbench for 30 mins, compare to the previous test, the max temp (76C) and avg temp (72C) are still same.
My system specs:
My build logs:
Your motherboard onboard VGA Intel graphics just had a driver update on the 13th.
Delete it if it was installed. Make sure it is disabled under bios/windows
Wow, how do you know that? Even I didn't have the clue about this.. How to check it? Does it really be the reason behind this?
My system specs:
My build logs:
Remove MSI LiveUpdate 6.
You do not want MSI pushing drivers automatically to your PC.
Watch for new drivers on their website yourself...avoid the Intel VGA driver since you do not use it.
If this fixes the problem, send MSI an email notifying them of a fault with their Live Update causing your overheating problem.
Will try to do it latter because I'm traveling atm.
I know 63C is still far to worry about, it is still good temps, but it's bothering me while I'm getting used to run it at far less than 60C since I use this Noctua cooler setup combo, but now it's over 60C.. It feels like the cooler starts fail me, it's not a good feeling..
My system specs:
My build logs:
