i5
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/972943-need-some-pro-tips/#findComment-11762469
6 minutes ago, Chubs said:
Currently my system is a athlon ii x4 635. im looking to upgrade it soon, the only thing is im on a budget I have a $100 to spend,
im choosing between an i5 2400 and an fx 6300 which should I go for?
the i5 2400 will be the better choice. try looking for a xeon e3 1230 or i7 2600 on ebay though, i've seen the xeon at $50 on ebay.
https://linustechtips.com/topic/972943-need-some-pro-tips/#findComment-11762480
The intel is the better one, but see what your motherboard supports at most and see if you can find it on a good deal
https://linustechtips.com/topic/972943-need-some-pro-tips/#findComment-11762484
12 minutes ago, Chubs said:
I do have a gtx 660 to pair it with
Your athlon uses ddr2 right? I think a used i5 with 4gb of ddr4 on a cheap h series board will do nicely. I bet you could find something like an i5 6400 in your budget somewhere like Craigslist.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/972943-need-some-pro-tips/#findComment-11762554
nope, my athlon uses ddr3.
https://linustechtips.com/topic/972943-need-some-pro-tips/#findComment-11762567
How much do you have?
Primary PC:
PSU tier list
https://linustechtips.com/topic/972943-need-some-pro-tips/#findComment-11762571
