So when trying to boot with 3.9ghz i get welcomed with this crazy Vcore, but the VID seems normal. What is the difference between the 2?
On normal overclocks they are both pretty much the same number, but when i tried 3,9ghz this happened. 1,5V is not safe, or does it just display wrongly?
Here is normal
I only see your reply if you @ me.
https://linustechtips.com/topic/972936-difference-between-vid-and-vcore/
One is measured by the CPU, one is measured by your motherboard.
IIRC, the measurement on the motherboard is before a portion of the power delivery segment of the board, so voltage and amperage will be different.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
vCore is the actual voltage the motherboard is delivering to the chip.
VID (Voltage Identifier), put simply, is what the chip is "requesting" from the motherboard.
CPU: Intel Core i5-8600K [Delidded | Frequency: 5.1GHz | vCore: 1.45v - Fuck Intel | Cache: 4800MHz | VCCIO: 1.175 | SA: 1.20]
GPU: MSI GTX 1080 Ti ARMOR 11G OC [Core: 2113MHz | Memory: + 1000MHz | Voltage: 1.181v | XOC BIOS]
RAM: TEAM GROUP DARK PRO EDITION [Capacity: 16GB - 8GB x 2 | Frequency: 3866MHz | Timings: 16-16-16-36]
Motherboard: ASUS PRIME Z370-A
PSU: SeaSonic PRIME Ultra 1000W
Case: Fractal S2 Meshify
CPU Block: EK Velocity | GPU Block: EK-FC1080 GTX Ti TF6 Radiators: x2 HWLabs SR2 360MM  Pump / Res: EK-XRES 140 Revo D5 PWM Fans: x6 Noctua NF-F12
Primary Monitor: Acer Predator XB271HUbmiprz [Refresh Rate: 165Hz | Resolution: 2560 x 1440]
Secondary Monitor: ASUS VG248QE [Refresh Rate: 144Hz | Resolution: 1920 x 1080]
UPS: APC Smart-UPS RT 2000VA [Online | Double-Conversion]
Benchmarks: 3DMark TimeSpy - First [1 out of 8571]
