Hey guys,
So I just upgraded my PC and I have noticed that my FPS is not shooting up for some weird reason.
My current set up is i7 3770, 12GB RAM (4th memory slot is poo), GTX 1070
I am usually playing on 1080p, low setting, very high shader and no MSAA or FXAA and I get only around 200 FPS, with some dips below 150.
While I was watching the major with high settings and a bit of MSAA, I had got around 80FPS.
Temps are fine, nothing goes above 50C, GPU load is around %60, and CPU load is %70, nothing gets maxed out.
Online I have seen an average of 300FPS at low settings.
Any idea?
https://linustechtips.com/topic/972855-csgo-low-fps/
Do you have a 240hz monitor?
I'd probably look in to why your memory isn't working properly. Either a bad stick or a bent CPU pin will be the likely cause. Try running with just 2x4GB sticks in the working dual channel pair of slots and see if that improves the situation.
https://linustechtips.com/topic/972855-csgo-low-fps/#findComment-11761615
I have a 144Hz monitor, but when the FPS goes below 150 FPS, the spray gets choppier. Look, I know it sounds ridiculous, but this is the only game where I need that high FPS.
Before I have upgraded for 12GB, I had 8GB and a GTX 770. I got roughly the same FPS on the same settings.
https://linustechtips.com/topic/972855-csgo-low-fps/#findComment-11761633
