So I'm thinking of building a new PC, here's the part list I've came up with: https://ca.pcpartpicker.com/list/XXNLpG
I already have 16GB of RAM, a 1TB WD Blue HDD, and a GTX 970 that I can move to this PC.
My build will be used for a little bit of everything including schoolwork, productivity, and light 1080p gaming.
I haven't added a case to my part list because I want some recommendations from you guys. I also don't want to buy an AIO liquid cooler because my past experiences with them haven't been great. I also want to overclock my CPU a bit so I've went with an 8600K and an EVGA Z370 FTW motherboard, as well as a decent CPU cooler. I want my build to be quiet, which is why I went with the DR4 cooler.
My budget for everything excluding the RAM, HDD, and GPU is $800 CAD.
So what are your thoughts on this build? Is there anything you think I should change? Thanks in advance.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/972660-thoughts-on-build/
I like this build. It would definitely be enough for 1080P gaming, and maybe even a little bit of 1440P, at some lower settings.
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759524
13 minutes ago, Starelementpoke said:
Seems fine. You could go with a Ryzen to be more cost effective, but looks fine.
Any recommendations for the case?
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759571
If it looks nice, and has all the features you want, at a price you're comfortable with, go for it. Only advice I'll give you? Unless you're trying to make an RGB monstrosity, don't spend more than $100 on the case.
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759576
I really don't care about how the build looks too much (it shouldn't look ugly though). I want my case to be quiet and have good airflow.
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759579
Yeah, just look for cheap cases that have what you're looking for. You can find good-looking cases for as little as $40, and ones that are very quiet with great airflow for the same price, if not, only slightly more.
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759582
Looks good. I'd suggest waiting for Black Friday though, it's only 7 or 8 weeks away and you can either save a significant amount of money, or get significantly better parts for the same budget.
Eh, the 970 won't handle 1440p that nicely.
RGB isn't the only thing that makes $100+ cases more desirable...
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759654
Yeah, it won't handle 1440P very well, I just said it's capable of it.
And yeah, RGB isn't the only thing, that was just a joke. There are plenty of reasons a case worth $100 or more is desirable.
And yes, Black Friday will bring some GREAT savings.
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759657
I've already waited a long time, and I can't wait any longer (not because I'm not patient but because I NEED the PC soon)
BTW, what do you recommend for a case that costs under $54 CAD
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759662
I wouldn't, I'd at least save up a little more to get something half decent.
https://linustechtips.com/topic/972660-thoughts-on-build/#findComment-11759671
