13 minutes ago, gh0stsh3ll said:
Hey folks,
I am looking for a material to dust filter my case.
Any idea?
pantie hose is a good option
also depends on how much room you have to work with, some foams might work as well like THIS
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/972516-dust-filter-material/#findComment-11758449
A thin foam would probably be good, depends on how much space and what level of filtration you want.
Builds:
https://linustechtips.com/topic/972516-dust-filter-material/#findComment-11758495
7 hours ago, gh0stsh3ll said:
Hey folks,
Any idea?
If you want to get premade or custom ones Demciflex is a good option. As for material itself some 20x20 no see um (bug mesh) works pretty well.
https://www.demcifilter.com/
-Moved to Modding Section-
https://linustechtips.com/topic/972516-dust-filter-material/#findComment-11759578
