1 hour ago, Kiksa said:
I want to build myself a gaming pc but can't choose  parts.I want i5 proccesor and gtx 1050ti and i have bugdet 600-650$
INTEL BUILD
PCPartPicker part list: https://pcpartpicker.com/list/C22KnH
Price breakdown by merchant: https://pcpartpicker.com/list/C22KnH/by_merchant/
CPU: Intel - Core i5-8500 3GHz 6-Core Processor  ($210.98 @ Newegg)
Motherboard: MSI - B360-A PRO ATX LGA1151 Motherboard  ($69.99 @ B&H)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-2666 Memory  ($69.89 @ OutletPC)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  ($45.97 @ Amazon)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($159.98 @ Newegg)
Case: Cougar - MX330-G ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $623.79
Generated by PCPartPicker 2018-09-16 05:08 EDT-0400
Here's something if u want to game and stream at the same time :
RYZEN BUILD
PCPartPicker part list: https://pcpartpicker.com/list/MrY629
Price breakdown by merchant: https://pcpartpicker.com/list/MrY629/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory  ($77.99 @ Amazon)
Total: $615.90
Generated by PCPartPicker 2018-09-16 05:13 EDT-0400
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758189
Why i5? You want used parts? Why 1050ti?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758212
16 minutes ago, mikedrewsmy said:
PCPartPicker part list: https://pcpartpicker.com/list/t8HvsZ
Price breakdown by merchant: https://pcpartpicker.com/list/t8HvsZ/by_merchant/
Motherboard: MSI - H310-A PRO ATX LGA1151 Motherboard  ($64.99 @ B&H)
Total: $618.79
Generated by PCPartPicker 2018-09-16 04:40 EDT-0400
Thank you bro and how much will be average fps in games like csgo/fort/pubg?
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758218
Total: $618.79
Well, with that motherboard and that ram, it will be impossible to add ram in the future. Not so good choice.
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758226
2 minutes ago, homeap5 said:
Why not? He is asking, you may help or not. :) I5 + 1050Ti is not bad combo. It's cheap and decent for most of games. Not everyone wants i7+1080.
You're right bruh i like i7+1080 but i dont have that much budget i can afford myself i5+1050ti and enjoy gaming :D
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758227
Because if he's streaming and recording a used 1600 or 1700 would be the better choice. The stubborn "i5 and 1050ti" thinking isn't a good approach but oh well, what do I know with my i7 and 1080  ¯\_(ツ)_/¯
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758246
Yikes sorry i thought i chose the B360. Hold on i'll change it.
Total: $623.79
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758248
Cheapest motherboards with 4 ram slots:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813144162&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16813119086&ignorebbr=1
76$
i5 8400:
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117824
200$
8 GB ram:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231890
70$
1050 Ti:
https://www.newegg.com/Product/Product.aspx?Item=N82E16814137055
180$
BeQuiet PSU:
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V5NC1928
60$
PC Case:
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V57M5138
90$
CPU cooler:
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V21E0643&cm_re=be_quiet_cpu_cooler-_-13C-001F-00004-_-Product
50$
=726$
And yep, budget is little higher than you expected. Probably because PC Case and CPU cooler. :)
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758250
Total: $615.90
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758258
Build something like this......
I hv included RX 570 instead of 1050ti... simply  because it is better....
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($199.79 @ OutletPC)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  ($71.98 @ Newegg)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  ($45.95 @ Amazon)
Video Card: Gigabyte - Radeon RX 570 4GB Gaming 4G  Video Card  ($171.00 @ Newegg)
Case: Cooler Master - MasterBox E300L MicroATX Mini Tower Case  ($30.98 @ Newegg)
Total: $616.58
Generated by PCPartPicker 2018-09-16 06:40 EDT-0400
https://linustechtips.com/topic/972481-need-a-little-help/#findComment-11758377
