Help with controlling fans
43 minutes ago, Famalam said:Hi I just figured out why. I am a real newbie lol. So my four case fans all need there own connection. So one of my fan is plugged into SYS FAN 3 Header on mobo while the other three are plugged to a SYS Fan 2 divider. So I plug divider into SYS 2 and then it gives me three extra fan plugs. Then each one of my fan is plugged into one of the plugs on divided. So basically one fan on SYS 3 and 3 fans plugged into SYS 2 on mobo. Then my cpu liquid pump is plugged into CPU_FAN header on mobo and my FAN ON RAD is plugged into SYS fan 1. Then I changed the settings for the pump to run at full speed. Do you think my setup is good/fine now?????
If you are fine, then its all good. You can connect multiple fans to single header. Just make sure that all fans have combined power draw under 1A, and that all of them have same connection type (3pin vs 4pin).
