Just now, DinhanhGamer said:
Thanks, btw should I put the fan as a push or pull config?
You should be putting the fans to pull air into the case from the outside. I don't know too much about AIO radiators so I can't say which side to put the fans on.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
Having the fans pull air through the radiator instead of push air over the radiator will reduce dust buildup
Primary PC:
PSU tier list
How many watts do I need?
not really.. reason for pull on the radiator as an exhaust is easier access to clean the dust/dirt from radiator.
push or pull does not determine dust build up on a radiator.
