What should i look for in a monitor?
HP24
I'm looking in the region of about £100 but I would be willing to raise that if nessesary. I want to build my first pc ( at the moment I plan to put a ryzen 5 2md gen and a gtx 1060 6gb in it. What resolution, aspect ratio, frame rate Should I look For?
for your system, a 1080p 60hz or 1440p 60hz monitor is fine. However, for your budget, a 1080p monitor will have to do. Monitors are too expensive in general.
Primary PC:
Ok the thanks  for that any idea on the aspect ratio???
16:9 is usually what people play in unless they have ultrawides.
My recommendation would solidly be a high refresh rate, 1080p monitor for if you do get a GTX 1060 6GB.
This one I found well reviewed on Amazon UK which is only slightly above your price point: https://www.amazon.co.uk/AOC-G2460VQ6-Monitor-DisplayPort-response/dp/B015510R4M/ref=sr_1_2?ie=UTF8&qid=1537028218&sr=8-2&keywords=aoc+75hz+monitor
Its 75hz (So nice high refresh rate & 1ms of response time), has build in speakers & support for a VESA mount and plenty of connection. Probably good enough for your needs just as long as you don't want to be doing any photoshop work
I once did the unthinkable, back many headphones ago...
I split an audio split, again
Ok thanks
