So i had a lot of problems with shadowplay not recording audio and microphone. This is how i fixed it:
Changed Windows default sound format from 24bit 48000khz to 16bit 48000khz on the audio and microphone part.
Then i downloaded DDU, booted to safe mode in windows and uinstalled all drivers (Also downloaded the newest gpu drivers before booting to safemode)
Then i uinstalled using DDU, disconnected my internett and booted to normal windows. Then all there was to do was to install the latest drivers. Ta-Da, everything works.
i5-13600kf, 16gb Corsair 3600mhz, Asrock z690 ac itx,  RTX 3080 , 1TB+1TB PREDATOR + Western digital NVME, InWin A1, Thermalright peerless assasin 120SE
https://linustechtips.com/topic/971623-shadowplay-not-recording-audio-fix/
