Hi Tech Tip geeks!
I am having an issue replacing the SSD in a Macbook Air model a1465.  The current drive died, and I've tried to replace it with 2 separate new SSD drives that upon trying to install OSX from a USB, the SSD isn't found by the system so I cannot install it.  I had no luck with a Samsung Evo 860.  Do I need to purchase a specific brand like an OWC drive?  https://eshop.macsales.com/shop/ssd/owc/macbook-air/2013-2014-2015?
Please help as I'd like to get this thing up and working again.
https://linustechtips.com/topic/971582-help-macbook-air-ssd/
I have never heard of anyone replacing a MacBook Air SSD with an over the counter M.2 drive. I would say yes, buy the OWC drive, it is specifically branded for the machine.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/971582-help-macbook-air-ssd/#findComment-11749682
I might be wrong, but from what ive heard, apple use a hardware level encryption on their boards which restricts the use of over the counter drives. Linus mentioned this in his recent Imac upgrade video. I might be wrong on that but better to not take that change and get the OWC drive.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/971582-help-macbook-air-ssd/#findComment-11749685
This is what I figured but I wanted to make sure.  Thank you!
https://linustechtips.com/topic/971582-help-macbook-air-ssd/#findComment-11749686
Ya you would need a branded apple ssd kind of like how to uprgade Imac ram you need special apple sodimm ram
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/971582-help-macbook-air-ssd/#findComment-11749695
