I got a Fractal R6 tower. I'm putting two 140 fans exhausting from the bottom, a 240 Rad intake at the front, 2x 120 fan intake from the top, and a 120 fan exhaust out the back.  I'm going to vertical mount my open shroud GPU (non-blower).
Is this the best config for cooling? or should I exhaust from the top fans and intake from the bottom?
There isn't a lot of available info for a setup like this.
https://linustechtips.com/topic/971048-fan-directions/
Intake should always be front and bottom, exhaust from top and back.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/971048-fan-directions/#findComment-11744321
5 minutes ago, emosun said:
front/sides = intake
back/top = exhaust
hence why your houses chimney doesn't come out in the basement
Isn't always the case. Really depends on the fan and clearance between the ground/table/etc and the bottom of the case. Natural convection plays a role, but any modern case fan will overpower it. If there's enough room between the bottom of the case and surface, intake fans on the bottom and exhaust on top is better, but if you have no clearance at the bottom, you won't really be pulling any air into the case from the bottom. In this case however @OmniChico, you probably want to listen to the above stated advice as it'll work best in your case.
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/971048-fan-directions/#findComment-11744351
I think its safe to assume that 99.99% of modern towers that are suited for custom builds have good enough bottom clearance for air intake.
https://linustechtips.com/topic/971048-fan-directions/#findComment-11744372
On 12.9.2018 at 6:52 PM, OmniChico said:
Thank you all for the advise!  Will do as you suggested: Two intake at bottom and front with rad, and 2x exhaust at top and one at back
Imo you should keep rad in front. It will benefit from more fresh air, while bottom should be good for extra freshs air. Your GPU is the one needing most case and for that bottom intakes are really for. Unless you'd be having full custom loop.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/971048-fan-directions/#findComment-11753646
