Little background. Brand new gaming laptop. ROG GU501. 16gb ram/gtx 1060...
I undervolt via throttlestop by -115, played games just fine, then i closed just cause 3 and started browsing on google chrome. I got a blue screen with the code "store data structure corruption".
Is this serious? Any fixes?
https://linustechtips.com/topic/970488-bsod-help/
"a critical structure corruption means window detected that one of its files has been modified or the data that one of its files owns in memory has been modified.
In this case it was the windows 32 kernel. This file is often under attack by malware, rootkits and viruses.
The first thing you would normally attempt is to start cmd.exe as an admin and run the system file checker.
sfc.exe /scannow
this will attempt to repair corrupted files from the hidden copy on your machine. Problem is malware just goes in and modifies the backup copy. Then you run
dism.exe /online /cleanup-image /restorehealth
this will attempt to repair your corrupted file from a trusted online source (microsoft update server)
after you get a good copy of the file, you would then try to figure out why it was modified.
IE do a malwarebytes scan or run memtest to see if you have memory problems unrelated to windows."
OR reset windows.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/970488-bsod-help/#findComment-11739118
sfc.exe /scannow
OR reset windows.
Running that scan turned up with nothing.
https://linustechtips.com/topic/970488-bsod-help/#findComment-11739134
Can you reset windows ?
this MUST fix this .
https://linustechtips.com/topic/970488-bsod-help/#findComment-11739141
Yes it should.
But you can always install drivers .
https://linustechtips.com/topic/970488-bsod-help/#findComment-11739223
