Hey guys, I'd appreciate it if you could help me out.
My setup:
I7-6700k
Asus Maximus VIII Hero Alpha
Corsair Dominator 16GB 3000Mhz
980Ti Hybrid SLI
Corsair RM1000i
WD Black 2TB and 1TB
Samsung 850 Evo 500GB and 1TB SSD
**New Samsung 960 EVO M.2 1TB
I installed the M.2 on my mobo, but I did not see it anywhere in BIOS except for when I looked in the Boot Menu. Upon entering Windows, I do not see the M.2 detected nor do I see it in Disk Management or Samsung Magician. I was hoping you could help me figure out whats going on, I'd truly appreciate it! Hopefully I provided enough information.
Thanks again
**Also, I have yet to change any settings in BIOS yet because even when I looked up what to do, I couldn't find anything useful pertaining to me.
***EDIT: I do see it in Samsung Magician after a restart, here is a screenshot I took in case it helps. https://gyazo.com/c45ab8b90b21a0da3764b2067bb314ec
https://linustechtips.com/topic/970313-new-m2-need-some-help/
1 minute ago, Alexsolo said:
Update the BIOS and make sure nothing is plugged into the PCIE slot that shares the space with the M.2.
@WaitDontSh00t
In which is the PCIEX4_3. Just make sure nothing is attached to that slot.
On BIOS . Go to Advanced \ Onboard Devices Configuration
Make sure the PCIEX4_3/M.2 is set to M.2 Mode instead of PCIEX4_3
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737529
13 minutes ago, mikedrewsmy said:
@WaitDontSh00t
Nothing is attached to that slot. For some reason that option is not showing up for where you told me to go. I don't see PCIEX4_3/M.2 anywhere.
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737598
hmm. Try removing the m.2 stick, and push it in more. Can u take a photo of the M.2 on the mobo?
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737604
I feel like it knows the M.2 is in there and secure. It shows in the boot menu. I'd take a picture if you really need it. Though I'd have to remove my second card again.
Very odd I'm not seeing that setting anywhere. Do I need to remove some of my drives to a different sata port? Would that be an issue? I honestly can't think of what else to try.
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737619
Since it shows up in boot menu, u don't have to take a photo or remove it.
U don't need to remove the sata port because it's running on PCIE not SATA.
Can you try going to Device Manager and see if the driver is installed there?
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_SEC&CttFileID=7036312&CDCttType=DR&ModelType=N&ModelName=MZ-V7E1T0&VPath=DR/201805/20180514160435960/Samsung_NVM_Express_Driver_3.0.exe&OriginYN=N <--- Link to the driver
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737635
In Device Manager > Disk Drives I do see my M.2 showing there.
Though it does still not show in Disk Management.
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737651
Can u screenshot both Device Manager and also Disk Management?
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737652
Disk 0 is the 960 Evo.
Right click it.
Just format and assign a drive letter for it.
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737673
Right click it.
I didn't even notice it down there at first, thought it would pop up on top to format. Thanks so much for your help. Much appreciated!
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737683
Enjoy the new drive :D
https://linustechtips.com/topic/970313-new-m2-need-some-help/#findComment-11737686
