8700K cooling
Go to solution Solved by 3 Lions,
Just now, Alexis31 said:
Ohh ok, Soo any not expensive but yet good option (About 100$)?
The Corsair H100i V2 is a good option or if you want to go slightly bigger the H115i is a good option.
Hey, I get 8700k + z370-a
now i have arctic 13 cooler that is crazily bad. Get after 4.7GHZ MCE and XMP profile OC and 95C.
I know now that the noctua nh-d15 is best but it's too big for my case.
i need something under 140 CM height and the best as posible with oc to 5GHZ.
Thank you guys!
https://linustechtips.com/topic/969762-8700k-cooling/
What is your case?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/969762-8700k-cooling/#findComment-11732218
According to the specs it says this case can fit up-to a 360mm radiator at the front, since you are using the top of the line CPU I think you should go the AIO liquid cooling route.
زندگی از چراغ
https://linustechtips.com/topic/969762-8700k-cooling/#findComment-11732239
زندگی از چراغ
https://linustechtips.com/topic/969762-8700k-cooling/#findComment-11732250
2 minutes ago, Alexis31 said:
I can connect it only in front
The front is better since it can fit bigger than single rads in.
زندگی از چراغ
https://linustechtips.com/topic/969762-8700k-cooling/#findComment-11732273
What's your core voltage set to? Have you tried lowering it?
https://linustechtips.com/topic/969762-8700k-cooling/#findComment-11732702
Thank you guys!
Use Thermalright Le Grand Macho RT!
It performs similar to D15 with 140 mm fan, more silent, better RAM clearance, 159 mm height, 1060 grams, big and bulky but not too heavy, might fit inside case that has 158 mm cooler height clearance, cheaper than D15. If I were you I would take Macho.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
https://linustechtips.com/topic/969762-8700k-cooling/#findComment-11734514
