GPU FRIED need help with diagnosing
Go to solution Solved by voiha,
13 minutes ago, mr dragev said:
500w that came prebuilt with my acer g3-710
PSU from a pre-built PC generally is bad. I would consider getting a better PSU as it will protect your PC and will be "more efficient".
Tho in this situation I think the PSU is at no fault as it's still working. Maybe a lemon card
http://imgur.com/gallery/oTMXoEU
Title. Pc shut off last night while i was in a game and it smelt burnt. The pc wouldn't boot, so naturally i removed the gpu and it booted. After unscrewing the cooler it clearly shows that it is burnt right by the power connector.
I'll buy a new card, no worries on that front. However i dont want this to happen to my next card.
I dont know what caused this. Could it be my psu? Or was i just unlucky? I can dive deeper into what happened if needed. The card is a gtx 960
https://linustechtips.com/topic/969374-gpu-fried-need-help-with-diagnosing/
Could be the PSU. What model is it?
Could be that some component on the GPU gave up.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Wow those ratings on that PSU... just 12-18A on the 12V rails... I have a PSU from 2004 with better ratings than that. Obviously not meant for a beefy GPU.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
