Hello,
I recently purchased a new gtx 1080 fr $350. It has a wierd problem. It's fan doesn't spin when I turn on the system. It only spins when I start playing games. What should be the possible problem?
Plz suggest me a solution..
https://linustechtips.com/topic/969032-problem-with-my-new-gpu/
3 minutes ago, SHROUD said:
Hello,
You can change the fan curves yourself.
Most of the time, the stock settings for fans are to spin at only >60C.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/969032-problem-with-my-new-gpu/#findComment-11724978
Also..why don't I get over 60 fps in rise of the tomb raider. I have seen reviews of gtx 1080s getting 100+ fps in rise of the tomb raider. Is my card thermal throttling because it's fans are not working??
I never got over 60fps in that game.
And yes....I play at 1080p
https://linustechtips.com/topic/969032-problem-with-my-new-gpu/#findComment-11724992
the fans are working just fine, they just run only when under load. your average FPS can be different due to variances in your CPU, ram, settings, etc.
https://linustechtips.com/topic/969032-problem-with-my-new-gpu/#findComment-11725001
PC Spec? CPU? RAM? Do you cook toasties in it?
https://linustechtips.com/topic/969032-problem-with-my-new-gpu/#findComment-11725016
1 minute ago, homeap5 said:
Install MSI Afterburner and set you own curve. If you want to spin fans all the time (what I recommended based on my experience, until of course your GPU is not loud), set it at 25% under 45 degree. Then straight line to 70 degree.
But my card isn't manufactured by msi...
It's a gigabyte g1 gaming card
https://linustechtips.com/topic/969032-problem-with-my-new-gpu/#findComment-11725051
