Help with Website
Go to solution Solved by Purple,
Adblock the element
I want to block a certain part of a page, but not the whole site. This is an example.
Let's say I want to hid the Boats tab, is it possible to hide it so I can't see it?
I'm sure you could make some custom script to do that. (I wouldn't know where to even start)
Don't know why you would want to do that though.
You could do what was suggested above but you would have to do it again each time you refreshed the page.
https://linustechtips.com/topic/96898-help-with-website/#findComment-1296444
Do you know anyone who knows how to do that script?
https://linustechtips.com/topic/96898-help-with-website/#findComment-1296480
Do you know how to make it so it is gone for like 10 minutes
https://linustechtips.com/topic/96898-help-with-website/#findComment-1296498
There is also a plug in called Page Eraser (iirc) that is quite simple. You just click the little icon for page eraser, click all the elements you want gone, and it will automatically remove them every time.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/96898-help-with-website/#findComment-1299578
