Ok, so I am in the process of choosing the parts for my pc, and this is what I have at the moment:
CPU: AMD Ryzen 5 2600x
GPU: MSI - Radeon RX 580 8GB ARMOR OC Video Card
MOBO: MSI - B450 TOMAHAWK ATX AM4 Motherboard
PSU: EVGA - B1 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
https://pcpartpicker.com/list/Ysf9nH (ik it says bq, but the one I chose is not listed.
I will be using 16gb ddr4 ram and a 1 tb hdd with a 125 gb ssd. My budget for the four listed above is around $500-$600. Do ya'll think it will be able to run games at 1080p 60+ fps and be able to run vr? Thanks so much!
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/968538-building-first-pc/
wrong link, the one with your parts listed is beside the word 'permalink'. don't get the 2600x and the B1, get the 2600 and overclock and a corsair CX/coolermaster masterwatt instead.
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720369
6 minutes ago, lmeneses said:
Wait did you already buy that GPU? because the armor cards have poor cooling in general
Masterwatt 550W or Corsair (2017) 550W is the way to go most likely.
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720371
4 minutes ago, TheFlyingTraut said:
Do you have a case in the budget? Fans? Coolers? Just stuff to think about.
I am most likely going to buy a cheap pc case, and I am planning on using the wraith spire included in the 2600x because most reviews say that it keeps the cpu cool, plus I do not plan on overclocking yet.
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720380
whoops, sorry lol, and since I am new to this, I do not know if I am going to overclock, so I just feel like I should get a more powerful cpu, but if it wont affect the performance that much ill look into it
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720383
I did not, but i will take that into consideration know, and I will look into those, thanks!
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720385
they're pretty much the same with a higher clock for the 2600x. overclock the 2600 and the performance is identical.
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720392
Oooh, hmmm, tough decisions, I appreciate the info tho!
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720406
Just buy the ASUS model I linked in the other thread, or maybe look to ebay, might be able to knab a higher end unit on the cheap.
Might even be able to get a top end model, either the sapphire LE/SE blue card, or Power Color Golden Sample. Wish I had waited just a bit on that front, prices have come down rapidly since a month ago.
https://www.ebay.com/itm/Sapphire-Radeon-NITRO-RX-580-8GB-GDDR5-PCI-E-VGA-Graphics-Cards-11265-01-20G/332789004409?hash=item4d7bc53879:g:aB4AAOSwmBdbhMsL
https://www.ebay.com/itm/Sapphire-Radeon-Nitro-RX-580-8GB-GDDR5-Dual-HDMI-DVI-D-Dual-DP-USED/173515463556?hash=item286653db84:g:XuQAAOSwnENbehft
https://www.ebay.com/itm/Powercolor-Radeon-GOLDEN-edition-RX580-8GB-Red-Devil/232913179847?hash=item363ab514c7:g:VYQAAOSwlzZbDznM
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720412
oooooh, oops sweet thanks so much! you've been a real help, and too true, i remember not too long ago those prices were in the $500s
https://linustechtips.com/topic/968538-building-first-pc/#findComment-11720451
