Graphics Card Sag
Solved by W-L,
1 minute ago, jayneisagirlsname said:So I bought this MSI Graphics Card Bolster as kind of a precautionary accessory for the MSI 2080 Trio that I pre-ordered. I hear that the newer cards are pretty hefty and tend to sag. Anyway, I tried it with my current card (MSI 1080 Gaming X), which has minor sag, and I noticed that the GPU temperatures increased when the support held the card at more or less a 90 degree angle to the floor (ie as straight as possible, no sag). And when I let the card sag just a touch, the temps returned to normal. Has anyone else experienced this?
Sounds like it has cause it to have a bad contact with the die since straightening out. You can reapply the paste in it's supported position to see if it improves.
