Hello all,
I'm currently in the market for a new PC.
As of now my build is a mixmatch of old and newer parts.
Current config:
- i7 4770K
- Z97AR
- 16gb of 1600Mhz DDR3
- MSI RX580 8gb Gaming X+
- 1 x 120gb EVO 850
- 2 x 500gb EVO 860's in Raid 0
- 1Tb SSHD
- RM550X
- H100i V2
- Various fans
Currently I live in Europe but for lack of parts and prices i used US partpicker for config.
What I think would work:
https://pcpartpicker.com/list/YMgTZR
I'm not sure if what I have is good for a Threadripper build since i'm switching over from Intel and the Ram speed is always confusing to me.
I want a PC for gaming but also for machine learning and for data science and non regression testing, maybe some video 4K editing as well !
Any build advice would be greatly appreciated.
Thanks!
M-P
https://linustechtips.com/topic/968071-i-need-help-with-a-threadripper-build/
threadripper doesn;t actually care as much about ram speeds as normal Ryzen chips. Pudget systems has a great explanaition on their site why this is: LINK
as far as the components go, it looks like a pretty solid build. if you want to go secondhand you could probbaly find a 1950X for 500 euros tough, so maybe that would be a etter deal than the 1920?
10 hours ago, RollinLower said:
Snip
Thank you for your reply.
I can find a 1920x at around the 400 euro mark, i'd love to go the 1950x route but I think buying a used chip without a warranty is a bit risky.
As for the GPU, I was wondering if I shoull wait for the new AMD GPU's to come out or if I should just get a Vega
