Alright so I have a second pc with windows 8.1 and I don't have the password for it and I want to keep the os on it, so then I was wondering if I plugged it into my main pc and ran it as a second HDD (not as a boot device) would i be able to access the HDD and delete the admin on it so I could make it mine, it was my neighbors he gave it to me after he got a new one and he doesn't remember its password.
https://linustechtips.com/topic/968040-hdd-help/
https://linustechtips.com/topic/968040-hdd-help/#findComment-11715694
19 minutes ago, Nul Atlas said:
Could you link me a tutorial for windows 8.1?
Its listed on that site, basically do this
  1. Get the machine to boot from the CD or USB drive.
  2. Load drivers (usually automatic, but possible to run manual select)
  3. Disk select, tell which disk contains the Windows system. Optionally you will have to load drivers.
  4. PATH select, where on the disk is the system? (now usually automatic)
  5. File select, which parts of registry to load, based on what you want to do.
  6. Password reset or other registry edit.
  7. Write back to disk (you will be asked)
What are you having a problem with?
https://linustechtips.com/topic/968040-hdd-help/#findComment-11715942
Im saying on the site it says it can only crack windows vista and xp, i tried useing it it brought me to the GUI but there were no tables where there was suppose to
https://linustechtips.com/topic/968040-hdd-help/#findComment-11716040
Alright so im already in and thing is when i got to input the command chntpw -l SAM it tells me there is no such file (yes i did do every command your suppose to before that)
did you open ophcrack?
Then load the sam.(its in c:\windows\system32\config then you can easily reset
https://linustechtips.com/topic/968040-hdd-help/#findComment-11716558
