oh, you use the Winforce one? Is it cool? and does it overclock well?
It's quite a nice cool, quiet card. My overclock is in my signature, but your mileage may vary :P
hah cool i have 1353 core clock :P if i go higher its unstable and valley will crash on me. also 7400 memory? how much is that in msi aftebruner or whatever u use?( like from 0 so as in + how much?)
Specs of my PC:
CPU: AMD FX 8350  Motherboard: Gigabyte 990XA UD3  GPU: Gigabyte GTX 770 Windforce 2GB  HDD: WD Green 2TB SSD:  Corsair Force GT 120GB SSD RAM: Corsair 8GB(2X4) PSU: CoolerMaster G650M
+400 I believe it is. I used ASUS GPU Tweak, but I have been running it at stock for a few days since I am going to install MSI Afterburner and try it.
how much did you pay for it?
I paid $399, but this is before the price drop. Now, they sit at about $329.
I probably won't clock it that high because you know of that there Fractal R(heat-trap)4
They're on Amazon and Newegg for $390.
Normally I've stuck with AMD but with the ridiculous prices I'm crossing lines.
Error: 410
It's been reallyt weird for me. I tried +400 and sometimes it was just fine in valley and sometimes it crashed. Sometimes even +410 worked and sometimes it crashed. Heck even 385 started crashign on me(like wtf 400 was working and 385 isnt?) So i bumped it down to +300 and core clock is +60
Specs of my PC:
Oh is there some heat problems with R4? I have an R4 and a 770(+60 core, +300 memory). Should I be worried? :P
Specs of my PC:
Is it worth getting the winforece one for 349 chf instead of the pny one for 299 chf?
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
It's not the coolest case in the world, especially when you have fans designed for silence and the vents covered.
It's not worth 50$ for the difference. I would get the 4gb one though if you're going to SLI later
Error: 410
yeah, my budget is pretty tight, I woukld have to save an extra month or two, to get the 4Gb version. Is it wort it, If I only play at 1080p?
Othewise I would go for the 280x. 3GB. (320$ atm.)
I have to wait 5-6 days for my replacement mobo!!! and thats just the time it take for them to confirm the fault then theres the wait for the replacement to be sent
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
First world problems? Not having all my money right this second so I can immediately spend it on the components to build my rig. xD
CPU: i7-3930K @ 4.8GHz MOBO: IV Gene RAM: 16GB Crucial Ballistix Tactical Tracer 1866MHz GPU: GTX 780 Ti CASE: Corsair 350D STORAGE: 2 x Samsung 840 Pro 256 GB, 2x WD Red 4TB
PSU
: EVGA SuperNova 650W DISPLAY: 1 x ASUS VG248QE, 3 x Dell U2414H COOLING: Corsair H100i INPUT: Corsair Vengeance K70, SteelSeries Sensei AUDIO: Sennheiser HD 280 Pro, ATH-M50s, Beredynamic DT770 Pro, Steelseries H Wireless
i still have dual 550TI's
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
If you SLI, and newer games might require more VRAM and you might upgrade your monitor in the future. 2GB is becoming close to not cutting it anymore. I would go for the 280x since it's pretty cheap where you are.
by the way, does it sag?
Error: 410
MY Galaxy Ace has infinate battery life and iv been listing to music with headphones (40m drivers) full volume for nearly half of every day for a week and its only 80%
PC Editing / Gaming Rig Specs : i7-3930k @ 4ghz w/ Hyper 212 Evo | 840 Evo 250gb and Seagate 1TB | 2x8GB Corsair Vengeance RAM | Zotac GTX 780 | Corsair Vengeance C70 Green | OS: Ubuntu 16.04 LTS / Win10 #KilledMyWife #MakeBombs
