Hey!
I'm looking to purchase this RAM for my HP DL360 Generation 5.
The RAM that is currently in it is a mix between HP and Hynix memory (PC2-5300F-555-11).
Should I come across any issues with installing the Samsung memory???
Thanks in advance.
My Machines:
I know. I need to update this. And I will. Eventually.
https://linustechtips.com/topic/967546-ram-compatability-help/
no you won't have any issue.
if it run, then it is compatible.
just try it on.
https://linustechtips.com/topic/967546-ram-compatability-help/#findComment-11711171
just try it on.
You sure?
You don't really fill me with confidence saying "if it run, then it is compatible."
I am seeking a simple answer that doesn't contradict itself.
I am only asking so that if I do purchase it, it isn't a waste of money an it works as it should.
My Machines:
https://linustechtips.com/topic/967546-ram-compatability-help/#findComment-11711179
just match the type of the memory.
if you have a ECC memory, then buy a ECC memory, not a regular one.
as for the manufacture, you can mix and match modules from different brand.
ask the seller for return policy, if it not compatible.
sellers usually give this policy 7 days after delivered.
from my experience i never had any issue with different memory brands.
https://linustechtips.com/topic/967546-ram-compatability-help/#findComment-11711193
