Hey guys so my best friend got some money together and asked me to choose and assemble a computer he said he had to be small (itx) good for gaming, streaming and CAD.
Here's the parts:
Ryzen 7 2700
Asrock Fatal1ty AB350 Gaming-ITX/ac
G.Skill 16GB (2xGB) DDR4 3000MHz Aegis
Now for the problem. I assembled everything and turned it on and all the fans spin but no post, I immediately thought either incompatible memory or incompatibility between the new Ryzen chip and the last gen mobo.
Any opinion on what the problem is and what's my next step? contact the seller? Mobo manufacturer? AMD?
None of the repair shops in my city in Portugal have a last gen Ryzen to do the bios update. Should I just return the mobo and ram, and buy a B450 and official Ryzen supported pack respectively? Help, We are lost and frustrated :(
https://linustechtips.com/topic/967299-ryzen-help/
order an amd boot kit or return the mobo and buy a b450
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/967299-ryzen-help/#findComment-11709005
Check to see if all the cables are plugged in properly. Because you may have not forced the 24 Pin or the 6 Pin Cables in all the way. Anyways if that doesn't help then it's time to use the warranty
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
https://linustechtips.com/topic/967299-ryzen-help/#findComment-11709011
Agree, or if you have a shop nearby you could see if they have a Gen 1 chip they can use to update the BIOS for a few bucks too.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/967299-ryzen-help/#findComment-11709020
Yup, AMD sends out a CPU for free to update the BIOS with.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/967299-ryzen-help/#findComment-11709130
assuming you have a dedicated grphics card (you'd plug the monitor into it) as asked what GPU do you have?
it is known that the 2nd gen ryzen may need a BIOS update on the first gen platform motherboards. ask amd for a boot kit or your retailer (who sold the items) if they have a way to 'make it work'.
https://linustechtips.com/topic/967299-ryzen-help/#findComment-11709216
